How do I eliminate boost creep on TTi kit?
Old 08-08-2006, 09:23 PM
blackbird345's Avatar
Default How do I eliminate boost creep on TTi kit?
I have the street kit, and I didn't have the right size wastegate spring so I pulled out the spring and figured I'd be ok since it would be running without boost, however, the car still builds boost. By redline in 2nd I'm building around 6 psi. Is there anything I can do short of getting a larger wastegate or exhaust housing?
Old 08-09-2006, 12:36 AM
Pathological Modifier
Ryan K's Avatar
So, no spring? How do you have the vacuum/boost lines hooked up? I have never seen boost creep with the TTi kit.
Ryan K.
Old 08-09-2006, 02:07 AM
Boostaholic's Avatar
Well you can only turn the boost so low, and trying to make 0psi is going to be hard unless you have some huge turbo
Old 08-09-2006, 05:21 PM
Thanks for the responses. Its a T76 Y2K so its a reasonable size but now that I'm thinking about it, I wonder if I put the spring back in if it will actually creep, I'm thinking it may not because the waste gate won't be over worked. I need to get a 3-5 psi spring, I'll let you all know when I get it.
Thanks,
Old 08-09-2006, 08:10 PM
I think I have a 3PSI psring for a TIAL gate that i dont need
Old 08-10-2006, 11:11 PM
Wanna sell it?
Old 08-10-2006, 11:34 PM
Originally Posted by blackbird345
Wanna sell it?
sure let me make sure i have it first ill post back here after i look for it either way.
Quick Reply: How do I eliminate boost creep on TTi kit?
