Looking for some write-ups on installing Fuel Rail Covers
I did a search,...but I can't seem to find any good write ups on how to install the fuel rail covers. I managed to get the passenger side on really easily,...but I can't figure out the drivers. The only write up I found was the one from the checkered flag store...but I can't seem to find the.... "large wire harness directly in the middle of the driver's side coil pack. This is clipped onto the coil pack with a small metal clip. Take a screwdriver or other tool of choice and gently pry this harness off the clip so that it will drop down a bit. If you leave it in place it will not allow the cover to seat properly."
I need better pictures or something. Does anybody else have a write-up?
Help.
Help.
The large wire harness in the middle of the coil pack is the weatherpack connector that is white and has a blue securing tab going through it. It's in plain site and you can't miss it. Pry it off the metal tab and let it drop down some.
Bryan
parbreak
Bryan
parbreak
