rapid shifter?
Old 08-12-2006, 03:17 PM
number1gun's Avatar
Default rapid shifter?
ok my uncle has a rapid shifter i don't know if it's an auto or stick theres no clutch but he has to shift through all his gears so i don't know if it's a manual or auto sounds like manual but on my car i can shift through 1st and 2nd like all auto so i need to know cause then i could use torque to my advantage
Old 08-12-2006, 05:29 PM
BlackHawk T/A's Avatar
If he HAS to shift through the gears, then he has a manual valve body.
Regardless, how is that in any way helpful to you?
Old 08-12-2006, 06:27 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Old 08-12-2006, 10:14 PM
number1gun's Avatar
ok he just shifts by the stick no clutch
it would be nice to have in my f-body
Old 08-12-2006, 11:30 PM
And it is an automatic? It has a shift pattern of PRND321 or similar?
If so you can do the same, get a reverse manual valve body and shift kit.
Old 08-13-2006, 07:45 PM
number1gun's Avatar
i dont know anything about shift patterns
all i know is he shifts straight back through his gears
