question about heads
Old 08-13-2006, 10:19 AM
layz's Avatar
Default question about heads
i am about to acquire a set of heads and wondering if i have to pull the motor to pull/put the heads on my 2000 z28....
Old 08-13-2006, 11:08 AM
slow trap's Avatar
no,you don't have to pull the motor.however i suggest you get some arp head bolts or studs so you don't have to mess with those gm bolts and the way they want you to install them.
Old 08-13-2006, 11:12 AM
2002blackZ's Avatar
http://www.ls1howto.com/index.php?article=3
follow these and you should be good... I would suggest you read them a couple times before you even get started and then follow along closely as you do it. Just take your time and make sure you have everything you need before you get started.
Good luck!
