Question about gears
Old 08-16-2006, 12:08 PM
lamanamanumi's Avatar
Default Question about gears
Hey guys, I have a 99 z28 and am about to buy 3.73 gears for it. My car car is an automatic and my friend said I should make sure there isn't a difference between the gears for a manual and an automatic. Just to make sure I need 10-bolt 7.5 right? Thanks
Old 08-16-2006, 12:46 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
This should be in gears & axles section....answer: any gears for a 10-bolt 7.5" will work.
Old 08-16-2006, 02:12 PM
BrandonDrecksage's Avatar
you need something else. I think 2.73s came witha series 1 carrier or some ****. The 2.73 gears are bigger or something and switching to a 3.73 you need spacers or soemthing..search in the drivetrain area..you'll find the anwser.
Old 08-16-2006, 02:25 PM
chadtx01's Avatar
Like Brandon said, the A4 cars that came from the factory 2.73's came with a different carrier than the A4 cars that came from the factory with 3.23's
A4 cars with 3.23's use the same gear as the M6, but the A4 cars with 2.73's are different.
Old 08-16-2006, 05:34 PM
NHRAMAN's Avatar
Exclamation
true...different series' need different things..sorry if I misdirected you.
Old 08-16-2006, 09:40 PM
SSDoubleK's Avatar
That's some good info., almost sold my 3.42's with the wrong info., nice post. Thanx.
