DOH!! need new torque arm
installed my pacesetter headers and attempted to install TSP catted Y. wont fit with my Spohn adj torque arm. i have the flat bar with a step in it, supposedly works for kooks i believe. wasnt sure if it would work with pacesetter and TSP. time for new torque arm with d.s. loop. whos got the cheapest UMI torque arms these days?
i would check with byunspeed or UMI directly for their stuff.
The Kooks y-pipe is one the of the best fitting y-pipes I have ever seen. It tucks tight against the floor and fits perfect. This is why manufacturers make items specifically to fit a Kooks a set-up, when ground clearance is important this is something to look at.
On the other hand the TSP y-pipe does hang low, this torque arm here will clear- www.umiperformance.com/2202.aspx. It will be close and the y-pipe may even rest on it slightly but will work good. We have installed a few with the TSP y-pipe, the y-pipes seem to vary, one clears nice and one is closer. But this will do the trick, the drive shaft loop will also clear fine.
If I can help anymore please ask. Thanks
Ryan
Ryan
i believe i have a older modle spohn torque arm that has a double bar(one 2" ontop and a full bar under that. anyone know its worth? still in good shape,some gouges and scrapes from speed bumps . doesnt look like the new models.
