Cleaning out the garage, lots of goodies FS
Old 08-20-2006, 10:31 PM
gearheads78's Avatar
Default Cleaning out the garage, lots of goodies FS
TNT LS1 Power Ring wet nitrous kit (less bottle) good used $300.00
28 x 11.5 x 15 (compare to 28 x 10.50 ET Drag) Hoosier QTP aprox 65-70% tread left $200.00
New DOT 28 x 11.5 x 15 ET streets (similar to 28 x 9 ET drag) $240.00
B/M Ripper T56 shifter barely used $125.00
New Turbo Action Cheetah shifter. TH350/400/glide was bolted in car for mockup only never used. $225.00 sold
New reverse manual valvebody TH400 with trans brake and deep aluminum pan. All fresh never installed. $850.00 sold
New Huges 4000 stall TH350/400 $400.00 + $30.00 if you want it with LS1 crank adapter sold
New Lokar 24" TH350/400 universal dipstick (out of package but never installed) 40.00 sold
Stock F-body aluminum driveshaft with rear joint set up for Moser 12 bolt $80.00
Vacuum modulated 4L60e with 3rd gear out. Was recently fresh needs to be gone back through comes with Vigilate 3800 converter sent to Vig less than 3000 miles ago $600.00
Richard 214-793-0029 leave a msg if I don't answer. Its hard to get to the web during the day so if you PM me don't expect to hear from me till later in the night.
Old 08-21-2006, 10:15 PM
bump...
Old 08-23-2006, 09:31 PM
updated..
Old 08-23-2006, 09:52 PM
skipperbisket's Avatar
on the stock driveshaft... what rear joint does it have? and what is it setup for? a4 or m6 or a3? thanks
Old 08-23-2006, 10:15 PM
Came out of a M-6 car but been using it with a A4. What would be the differance? Ujoint is 1 1/8" cup / 3 5/8" span across
lmk
Richard
