walbro pumps...
walbro pumps...
http://shopping.lightningmotorsports...-p-1-c-14.html
which one will i need. goin to do the dual intank setup i guess. i have the plug and play from racetronix so what will ihave to do to make it work? or does a sponsor sell them for this price on the board?
Remember there is also an install kit you will need it has a wire haness with plug and filter sock. We have the pumps with install kit for $129.99 I would sell the Racetronix kit and use 2 new pumps and instal them together. The 98 is a pretty easy install.
Nate
Nate
341..341...307 pumps..as long as its a 255lph pump.
nasty is right..u will need an install kit too..has the wiring harness and sock filter. you will need to go to your favorite rice auto parts store and get a t or y fitting and ~5ft or so of high pressure hose to get everything hooked up in the tank.
Not nessesarly the 340 is the pump you are looking for Walbro makes alot of different pumps and most are for 43psi systems yours is 58psi you need to know the pump is up to the task.
Nate
Nate
