4l80e in a Trans Am?
Old 08-21-2006, 02:08 PM
phildo's Avatar
Default 4l80e in a Trans Am?
Will this work? can I use my 4l60e converter or do I have to buy another? Are there any mods that have to be done to make it work? Thanks
Old 08-21-2006, 03:12 PM
Tech Resident
ChocoTaco369's Avatar
- yes, it will work, but it requires modification, both to the chassis (as in you can't just bolt it on, things need to be altered) and the PCM. there are writeups on this site, search for one.
- you will need to buy a new stall. 4L80's take different stalls.
note that the 4L80E is a heavy trans and is best suited for higher horsepower (600rwhp+) applications where the extra weight becomes meaningless. of course, if you don't mind the extra weight, it'll likely be the last trans you ever buy.
