paging speedyWS6
Old 08-21-2006, 09:26 PM
NOTAV6's Avatar
Default paging speedyWS6
hey man i got a problem, heres what i posted up in the electrical section you got any ideas on what i should check
my driver's side brake light works but everynow and then it has stopped working for short amounts of time. did some troubleshooting today see if i could figure it out. heres what i found/ with the lights off, you turn on the passenger side blinker and then turn it off the driver's side brake light doesnt work, you then turn on the driver's side blinker and turn it off and then the drivers's side brake light works again. also if you hold down the brake pedal all the brake lights work you then turn on the right side blinker and turn it off the driver's side brake light will go off when you turn off the right blinker but all the other brake lights stay on. WTF this is just messing with my head
Old 08-21-2006, 09:39 PM
SPEEDYws6's Avatar
Replace the flasher/blinker module. The little can looking deal to the right of the stearing column.
