FAST 78 vs 90mm
that sounds great,anyway is the only difference between the two manifolds the throttle body opening?,are the runner volumes the same??
I know to get the 90,but i am curious if its gains over the 78 are from the larger TB opening..
Same everything except the bigger throttle body inlet hole. Very big difference in size. 78 vs 90 mm.
Thanks a lot for the info,i guess we can say that the stock 75mm tb is just to small for a H/C car over 400 rwhp.
