mass air question?
Old 08-22-2006, 03:33 PM
allthrotle's Avatar
Default mass air question?
How much boost are you guys running on your stock gm mass air sensors?
And how much boost is safe to run on a stock gm mass air?
Old 08-22-2006, 03:38 PM
MECHAM's Avatar
u can run as much as you want...it will stop reading at 512 and 439 depending on the year of the car. you have to compensate by adjusting values in the ecu to add more fuel...2bar/3bar upgrade works too...
Old 08-22-2006, 04:01 PM
slow's Avatar
Does it stop at 439 on the 98's or just at 11250hz instead of 12K
Ryan
Old 08-22-2006, 04:50 PM
Coal Mining Director
onfire's Avatar
16.4 psi
next year 23psi.
Old 08-22-2006, 09:15 PM
MECHAM's Avatar
Ryan
i know it stops at 439...not sure what that coorelates to in hz for the 98s.
but if you have hptuners/ls1edit/efilive..u can scale the maf like the 99+
Old 08-23-2006, 12:55 AM
allthrotle's Avatar
So if you upgrade to a 2bar or 3bar mass air its able to read and adjust for higher boost?
