please help keep blowing slave cylinders
Old 08-22-2006, 09:04 PM
1bad408's Avatar
Question please help keep blowing slave cylinders
please help keep blowing slave cylinders i have blown 2 i have a spec stage 4 the first one was the stock gm slave the 2 one a luk from autozone but i dont see y i keep blowing slaves please help
Old 08-22-2006, 09:17 PM
chino_man279's Avatar
How are you bleeding the system after you install it? I know some people have blown out the seals by pulling too much vacuum with the mityvac.
Old 08-22-2006, 09:25 PM
1bad408's Avatar
i dont use no vac bleed it normal way never had any problems the way i do it
Old 08-22-2006, 09:34 PM
Hmmmm...I dont know then. I am running the spec 4 with an updated GM slave with no problems for about 9k miles. What master cylinder are you running? I still have my stock 98 master in.
Old 08-23-2006, 12:58 AM
The PAT WS6's Avatar
yea i would buy the oem one or the ones from orielys it is still the oem one even tho its made by brake best
Old 08-23-2006, 01:01 PM
1bad408's Avatar
Question
it is the stock one from my 2002 ss it onley has 26000 miles on it
Quick Reply: please help keep blowing slave cylinders
