First run of the car at the track...
Well I'm into the 12 second club now. Started out the day with a 13.029 @ 112.61 with a 2.258 60.. times were all over throughout the day tryin to figure out how to launch this but ran a best of 12.553 @ 113.26mph w/ 2.018 60'.
This was on all season 275/40-17 Toyo Proxes 4's at 25psi, launched at 2200rpm roughly slightly slipping the clutch. I did burnout to heat them up even though they are street tires. Always seemed to help a bit.
Mods are as follows:
Engine:
GM Performance Parts ASA cam (226/236 .525/.525 110lsa)
QTP long tube headers/Dual Electric cutout off-road y-pipe
Whisper lid/K&N filter
BG Ram Air Kit
SLP fan switch
LG Motorsports "Supercool" rad w/ built in oil cooler
LS7 Clutch Kit
Suspension:
Eibach Prokit springs
Koni Yellow D/A front shocks
Bilstein H/D rear shocks
Strano 35 mm hollow front bar
LG motorsports aluminum LCA's w/ rod ends
LG motorsports chromemoly APHB rod end/poly
LCA Relocation Brackets
and here's the video:
http://www.finishline-photography.com/vids/josh1255.wmv
Engine:
BG Ram Air Kit
SLP fan switch
LS7 Clutch Kit
Suspension:
Thanks yeah I ran a 12.9 earlier with a 2.3 60' as well so I knew there was room to improve it was just nailin the launch, had a best 60' of 1.97 which netted a 12.57 @ 113mph. I need to get heads on there, a different rear end and some stickies next
