Problem out of no were.
Old 08-25-2006, 07:18 PM
ele-blue95's Avatar
Default Problem out of no were.
This is what is going on. The other day I was comming to a stop and went to down shift and the trans made a weird wineing noise on clutch engagement. My car is a 95 t-56. The trans made the same noise 4 months ago when I had it rebuilt new everything. The trans shop said when they had it apart that there was nothing wrong with it. And it started vibrateing before each shift like a bolt had come loose. It does it more when the car is hot vs cold. It has a fidanza flywheel and spec stage 2 clutch. any help would be great. thatnks
Old 08-26-2006, 08:26 AM
ele-blue95's Avatar
I have some more info to help out. Now you feel a weird hard to discribe feeling in the shifter when you shift in 1-2-3 up and down shifts. and you can feel it in the clutch pedal when you engage the clutch. The clutch resivoir has a film in it. I have a new OEM slave/master on the way, hope it does the trick.
