What else Do I NEed?
Car is stock....
Planning on Buying Corsa Cat-Back, Pacetters LT, and TSP's Catted Y.....do I need the O2 extensions as well?
What do I absolutly need to finish the setup? Gaskets? I want this to go as smooth as possible. Unbolt and bolt on but want everyting ahead of time before I start tearing into the car.
Thanks!
Thanks!
Originally Posted by Starz T/A 17
yea you will need 02 extensions, also you may need 02 sims im not sure if the TSP catted Y pipe has the 02 bungs for the rear
Originally Posted by RrCoX22
and to add.... a set of new GM exhaust mani. gaskets
