ls2 header question
i have an ls1 with ls2 heads on it, can i use a header for an ls1 or will it not work?
The LS2 heads are the same 243 casting heads on the 03-04 C5 ZO6 corvettes. The header bolt pattern are the same as the LS1 F-bodies. But make sure that the headers you get is for a F-body and not a vette and they will bolt right on.
That's what she said...
LS2 heads = LS6 heads. Bolt pattern/location is exactly the same. 6.0l, 5.3l, 4.8l, LSx heads all have the same exhaust setup.
