looking for fog light lenses
I had both of my fog light lenses fall out or taken out in my 99 t/a, was wondering If there were some colored lenses that I could purchase or even clear ones?
i didn't want to change the whole assembly, unless I absolutely had too...
Copy & Paste Moderator
The fog light lenses are not removeable in the 1998-2002 Firebird.
Either you have aftermarket fog lights or they are broken. You'll have to either glue them back together or replace the entire fog light housings.
thats what I was thinking, they are oem fogs but i didn't think that the lens came out of them, maybe they were broken before hand who knows, but thanks for the help
Restricted User
ebay has the fog light housings, like $70 each side...so $140 total, better than the dealer where you WILL get raped on pricing...orrr used "decent" housing at $50 per side...or $100 total, either way these housings are expensive as hell cuz NOBODY makes semi-cheap replacements, only the DEPO replica OEM housings...which like i said can be ound on ebay or a few other places hope this helps, latR
So on LS1 T/A's the lenses dont separate from the housings? I find that hard to believe, they may be glued in but can deffinatly be separated apart. A rock shattered one of the lenses on my 96 T/A and i just took out the other lense traced the shape on a piece of paper and took it to a glass shop to have 2 lenses cut out. They arent curved tho but rather flat, but you cant tell the difference. I think it was only like 25 or 30 bucks. I think thats the best way to go. That was like 3 years ago and havent had a problem.
I think the $60 aftermarket setup I have is a better and easier idea.
http://www.fadingarrow.com/FogLights.htm
