Took Thermostat Out Should I Get A 160??
Old 08-28-2006, 04:36 PM
bjamick's Avatar
Default Took Thermostat Out Should I Get A 160??
as the title says i have taken out the thermostat over the summer so it would stay a lil cooler but should i buy the 160 degree thermostat that everyone in the world has? i do have HPtuners so i can turn my fans on whenever i want to. would this be a mod i will NEED?
Old 08-28-2006, 04:49 PM
Gearhead1's Avatar
I wouldn't ever run without a thermostat of some sort. As for what temp to go with...to me it would depend on where in the states you live. It get's too damn cold here in the winter months for me to run a 160 stat. I compromised and am running the factory installed one. (I think it was rated at 187)
Old 08-28-2006, 04:56 PM
2001NBMZ28's Avatar
Took the thermostat out? Do you have one of the new pumps?
Old 08-28-2006, 05:30 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Thumbs down
Taking it out is a trick from the late 50's and early 60's......for gods sake, as well as the longevity of your engine , put one back in. .................THIS IS ...NOT...A MOD YOU ARE PERFORMING WITH YOUR BELLS ON... [or, are you.???]
Old 08-28-2006, 05:59 PM
HotWhipT/A's Avatar
Lol, call him Butters because he's on a roll!!!
Old 08-28-2006, 06:17 PM
cws T/A's Avatar
well my cars mostly stock I was weary of the 210 degree temps for high performance driving . I had it at my fathers shop to see where the actual temp was when the fans cut on /off . Stock no programing 187degree stock thermostat . The car ran a consistent 210* on a real gauge 210* showed on the dummy . ac on/off didnt matter it hovered around the same temps. I ordered a Be-Cool 160* thermostat and still no programing to lower the fan kickon on a 95* day with the ac off no fans even come on in stop and go traffic so I figure Im around 180* . I am going to go check it again on a real gauge to see the actual temperature . The dummy in the cluster is still 210*
Hope this helps.
Old 08-28-2006, 06:21 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Running a 185 here and I'm in Texas. Your car needs to be at a warmer temperature to operate properly. You don't want it running too low. Lots of people do not know this.
Old 08-28-2006, 10:48 PM
bjamick's Avatar
bad thing is it still stays round 210 so it still sucks. ya i just took it out no punp or nothing just stock.
Old 08-28-2006, 11:05 PM
Tech Resident
ChocoTaco369's Avatar
stick a stocker in there and program your fans to come on early or get a manual fan switch IMO.
Old 08-28-2006, 11:18 PM
cws T/A's Avatar
The Be Cool I bought says it wont let the engine overcool itself .wtf ? Me trying to put 500miles on my new clutch so I drove her around tonight for 2 hours with as much stop and go . when I got home I popped the hood and left it idleing I thought the fan would at least turn on once but it didn't . never heard the fan the whole drive .
Old 08-29-2006, 04:09 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Do you have it programmed to come on at 195-210 or something?
Old 08-29-2006, 06:09 AM
cws T/A's Avatar
the fans are still on their stock settings , before the thermo install they cut on at around 210* . If I turn on the a/c I can manually get them to come on so they are still working properly
Old 08-29-2006, 07:23 AM
bjamick's Avatar
well i dont know how to work my HPtuners yet but this weekend me and my friend who knows how to use it is going to show me how to work it and everything so i guess then ill get him to turn my fans on at like 180 or something!!
Old 08-29-2006, 05:27 PM
cws T/A's Avatar
well im DEAF my fans are running both of them . I went back to the shop and hooked up a OBD2 scanner .the engine coolant temp was 226* This was starting it after I turned it off from getting off the highway . My temp was about 219* steady. I need to lower my fan kick on some feirce . I got t boned for 60 bucks for the Be- Hot themostat . I run 93 octane and it showed I had 0 knock at this temp . I also found I have a miss on the #2 cylinder at idle .
Quick Reply: Took Thermostat Out Should I Get A 160??
