ls1 ls6 swap question
i have a 2000 ss camaro ls1. i am talking to a guy about a ls6 from a o3 z06. my plans are a stroker motor and aftermarket heads. the prob with the engine is a droped valve seat i am told. that will all be replaced anyway so i am not woried about that. my question is will this ls6 from an o3 z06 bolt into my car with out any major modifications to the harnesses and just swaping the pans after the rebuild? i am almost possitive it will be a direct swap but figured i could ask a few folks with more expirence. thanks ahead of time
As far as motor goes, yeap pan is all that is needed. Now about peripherals you'll need to reuse your TB, starter location, your crank pulley and other stuff. etc...
