F-body T-56 input shaft question
how many teeth or are the input shaft for a 99 vintage F-body? It isn't already 26 tooth is it? I looked at some of the T-56 upgrade packages and they don't mention the IS or the OS? Are there no upgraded cutch packages for an upgraded input shaft? I swapped in the Liberty 26-t IS on my tremec and could get most RAM clutches to fit it, but it looks like I don't have the same choices for the F-body?
I'm a tard on searches but I tried and found a bunch of good stuff about work they do inside the trani for quicker shifts racing (face plating/pro shifting/adding viper gears) but no mention of swapping to a heavier Input Shaft? just curious so I can order the right clutch, I don't see those clutch choices so there probably isn't that option for F-body, maybe if someone could confirm that I can move on, thanks.
Originally Posted by orangeapeel
It is 26.
