Oil evac setup vs: catch can / pvc setup
Old 09-03-2006, 06:06 PM
longrange4u's Avatar
Default Oil evac setup vs: catch can / pvc setup
Ok fellas... what is the difference? Cost difference? Complexity? Advantages and Disadvantages?
Old 09-03-2006, 06:52 PM
67Firebird455's Avatar
Hey buddy, think I had brought this up once before. Running like the moroso evac system like an NA car would... Answer basically was that you would have to run the line back to your downpipe, and that they said the checkvalves on the scavenge system would fail due to the heat at the turbo. Running a catch can setup to the intake side of the turbo would work though, which is what I will probably do.
Old 09-03-2006, 09:01 PM
Yea but you dont want to evac to a rear mount before your turbo... that would be a long line down to do it after.
Old 09-03-2006, 10:41 PM
navymitch12's Avatar
i am in the same position man...i am still not sure how i want to do this....i am thinking i am gonna end up running the line all the way back to the turbo .....or run a scavanger pump...but i dont really want to spend that much money
Quick Reply: Oil evac setup vs: catch can / pvc setup
