Do I need a new master cylinder?
Many of these threads are repeats. Now I find myself asking the same question as two thousand other guys. Two weeks ago my clutch began to stick to the floor under hard acceleration. Therefore, after doing a search I have decided to replace:
the clutch
the slave cylinder
the pilot bearing
and the flywheel.
Do I need a new master cylinder as well? If I replace the master cylinder should I get a McLeod adjustable master cylinder. I did search and there was some negative feedback on the McLeod. You comments are appreciated.
Thanks
the clutch
the slave cylinder
the pilot bearing
and the flywheel.
Thanks
Mine started it when I changed to the hotcam with 243 heads. It really pissing me off. My clutch has less than 10,000 miles on it. I changed the master and the slave and the fluid. The pedal actually drops to about an inch from the floor under heavy acceleration. I then wrapped my headers and put a heat shield sleeve over the hydraulic line. Could all this be caused by me missing the tin heat shield from the factroy? I would think that wrapping the headers and the clutch line would be equal to or better than the factory heat shield. Im going nucking futs with this. I just want to beat on my car once and get through the gears.
