So not much talk about aftermarket oil pans eh? (Canton, Autokraft)
Old 09-08-2006, 01:15 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
Default So not much talk about aftermarket oil pans eh? (Canton, Autokraft)
I'm kind of surprised, I did a search and found very little talk about aftermarket oil pans. I believe Canton and a company called Autokraft make some. I know all about dry sumps so let's not go off tangent.
Any real world experience with either, good or bad?
PSJ
Old 09-08-2006, 02:36 PM
Cstraub's Avatar
What application for the pan?
Old 09-08-2006, 03:21 PM
BlkHwk's Avatar
The Canton Pan looks kinda weak to me (structurally). Just by pics never seen one in person. I was considering an aftermarket pan but finally decided to stick with the stocker.
Old 09-08-2006, 03:32 PM
02Z28's Avatar
Moroso makes one now too.
Old 09-08-2006, 03:51 PM
383ss's Avatar
I've done a little research into them and asked some sponsors about them. they all said they are a waste of money. no real benefits over the stock pan and some have fittment problems.
Old 09-08-2006, 03:55 PM
tim99ws6's Avatar
anyone wanna pull prices for the options?
Old 09-09-2006, 12:57 PM
LS1Tech Co-Founder
Interesting. I'm a little busy right to find some links, but maybe someone has some actual experience.
Old 09-09-2006, 02:12 PM
HeapaShifter's Avatar
Speed Inc sells the Moroso and Canton oil pans. http://www.ls1speed.com/catagory.cfm?catagory=Engine..
Thunder has the Canton. http://www.thunderracing.com/catalog...&sid=557#P4041
Both oil pans have trap door baffling for improved oil control and I believe they're both lighter too.
I don't have one. My oil pan is stock.
Old 09-09-2006, 03:23 PM
LS1Tech Co-Founder
Hmm Moroso one looks nice. $641.
Old 09-09-2006, 03:49 PM
Ferocity02's Avatar
Quite frankly, I've never seen any real world benefits from an aftermarket oil pan, at least not for street use. To me, the cost to benefit ratio doesnt look very good for aftermarket LS1 oil pans.
Old 09-09-2006, 05:28 PM
LS1Tech Co-Founder
I have no personal experience with aftermarket oil pans except maybe for a Milodon pan that I used under a SBC back in 1992.
Old 09-09-2006, 05:40 PM
Phoenix 5.7's Avatar
don't have one, but i briefly checked into an aftermarket one. i did like the drain plug that some of the aftermarket ones have
Old 09-09-2006, 06:26 PM
Rob Hood's Avatar
So far the only aftermarket pans I've seen are for straightliners. I was curious about the LS2 pan because it has more oil control baffling for roadracing or autocrossing, but I think the LS2 pan won't fit the F-body.
Old 09-09-2006, 11:11 PM
MiaSSmaro98's Avatar
600 bucks for a pan that the stock one will work perfect for mostly all mods save the money man
Old 09-11-2006, 11:29 AM
LS1Tech Co-Founder
Interesting. So the pans are not selling well, and that's also maybe due to the lack of real-world usage by members.
Old 09-11-2006, 11:51 AM
Race your car!
JL ws-6's Avatar
I'm about done with a new motor, and I asked about the aftermarket pans.. and was told it was a waste of time and $... I also asked about a girdle, and the jury was out on that one, Ken @ eastside said he had used oen once, because he needed more clearance in the pan for a alum rod stroker motor, but that was the only reaosn, and it had a leaking issue with the girdle on ( girdle shimmed down the pan for clearance )
The dry sump has advantages, but I think there's nothing to be gained really from changing to another style wet sump.
Old 09-11-2006, 12:17 PM
Viper's Avatar
I too had a new motor put together in 05', and didn't get a pan. However my engine builder did put a canton pickup on the existing system; looks like a small box with screens in it vs. the stock one. I autox and roadrace. Local guy built the pickup.
Old 09-12-2006, 01:12 PM
Cop Car's Avatar
only reason why id see the usage of an aftermarket pan would be for more oil, or if you are doing a swap ie LQ4 into something, where you dont already have an LS1 oil pan. F body pans are something like $411 from GM, so even if you screwed up your pan, buying one from GM saves you at least $200 over an aftermarket that you dont really need....
i do however want to buy an aftermarket dry sump pan
