Back to stock: Comp Cams Adjustable timing set, lower sprocket has no dot?!
I am trying to put my car back to stock, but it looks like the Comp Cams adjustable timing set has no dot on the bottom sprocket?
I want to just put my stock timing chain and sprockets on but dont know how to make everything line up internally. I know I have to match the dots, lol, but not sure how the inside of the motor is sopposed to be lined up when those dots are matched.
Please help
Please help
Restricted User
Pull the comp sprockets off. The stock lower sprocket can only go on one way. Once you get the stock sprockets just line them up dot to dot.( The comp lower sprocket is 2 piece I am pretty sure, when they are installed you really can't see the dot on the bottom sprocket).
