02 sensors new but acting up
Old 09-13-2006, 03:02 PM
tomss99's Avatar
Default 02 sensors new but acting up
i got these codes.... p0131 02 sensor circuit low volts.... bank one
p0151 02 sensor circuit low volts bank two.....
i used the c5 rears for the fronts like everyone told me too... any reason why they would start acting up....
makes the car miss at low rpms... but goes away when im on the gas some more.... how should i go about fixing this? should i just buy new sensors... that would suck ***
Old 09-13-2006, 03:27 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
MINE WORK GOOD # 13111 BOSCH vette 02 sensors..???
Old 09-13-2006, 03:58 PM
ArcticZ28's Avatar
What was the reason you replaced them? Maybe the thing that caused them to go bad is causing these new ones to act up as well.
Old 09-13-2006, 04:04 PM
Charlie@LsXperts's Avatar
those sensors did the same thing to me for about the first month that i used them and then it stopped.... btw if you wash off your motor you might get misfires because everytime i wash my engine i get misfires bad!
Old 09-18-2006, 09:49 AM
tomss99's Avatar
i think i just have some bad injectors.... gotta get a hold of newer ones and see
Old 09-18-2006, 03:38 PM
bjamick's Avatar
hey my car does the same thing like when im sitting at a light (im an a4 by the way) my car is like sputttering and when i give it gas it hops like once and then it goes away and then my ses light came on and it went away ive gotta check the code with my HPtuners 2 nite to c what it is, but i believe its our o2s.
