stroked turbo setup, why 6.0L block?
Old 09-22-2006, 01:28 PM
TINKRD's Avatar
Default stroked turbo setup, why 6.0L block?
i read alot of people chose the 6.0L block instead of the 5.7 aluminum block?
is there an advantage? is the extra weight worth the added strength of iron vs aluminum?
just curious.
Old 09-22-2006, 01:40 PM
Restricted User
NOSjohn's Avatar
If an aluminum block is prepped correctly, it will last and can possibly make some big power. A properly prepped iron block will handle at least a little more due to the rigidity of iron vs. aluminum.
Old 09-22-2006, 03:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
Somewhere around 700rwhp or higher, some shops prefer the iron blocks since the aluminum blocks can experience some expansion due to heat.
