Is there a special flywheel to put a T56 on a 6.0? Stock one won't work...
Old 10-01-2006, 10:45 AM
RyanA's Avatar
Default Is there a special flywheel to put a T56 on a 6.0? Stock one won't work...
Well, went to put the flywheel on the 6.0 today and noticed that the crank sticks out about an inch (1") farther than the LS1 crank does. Flywheel would not even come close to matching up with the starter not to mention the issues of putting the trans on.
Is there a flywheel that can be bought for putting a T56 on the 6.0 that has the crank that sticks out the back???
Ryan
Old 10-02-2006, 06:37 PM
SVC707's Avatar
im running the same lightened oem flywheel on my setup, not sure where you are having problems... put it on no problems what so ever
Old 10-02-2006, 07:27 PM
RyanA's Avatar
You don't have the 6.0 that the crank sticks out the back of the block about 1/2-3/4 of an inch then, do you?? If you bolt up the flywheel, the starter would not even be able to engage as the flywheel sits too far back....
Old 02-11-2007, 07:22 PM
1999ssls1's Avatar
How did you get it to work?
