Debating about selling my ls1/fox project...
93 notch, NBM (Almost the same color... not sure yet)
MMR Tubular K-member for 96-04 Modular installed
Maximum Motorsports CC plates
MMR Front Coil over kit for Street/Drag
MMR Rear Coil Over kit
MMR Tubular A- arms 87-93 (not installed yet)
Has the stock 02 ls1 raidator and fans mounted in it using stock placement mounts
Has a double hump GT cross member that just needs to be put on the cut the tab so it is adjustable.
2002 LS1 with 28k miles on it
2002 4L60E mileage matched, same car(02 WS6, I think... gotta find the paperwork)
The motor is a complete dropout and the power steering reservoir was the only thing that broke during shipment-- so I have a brand new one. The engine is complete--- harness, ecu, and all. Even has the ac brackets + pump.
I hate to do this, but due to a dumb *** of a car builder, I didnt have the time, nor place to do the project, so I paid someone to do it (up front) which was a huge mistake. 12 months later, still not even close to done.
So this is my pissed off thread--- if you want to buy the project as a whole, please give me a reasonable offer... I didnt skimp on the swap parts.
Ill have pics up this week, or feel free to come by and check the stuff out in person. My cell is 949-355-3395 and my name is Garrett. Thanks for looking.
Also--- to save your time, please dont be a dumb **** when offering on this project, we all know what everything pieces out for. Thanks.
Great for weight savings, header clearance, and 5.4 swaps. Requires A-arms and Front coil over kit, also fits 87-93 for Modular conversions 800100 $349.99
Fully adjustable ride height, quality 6061 Aluminum w/ Torrington bearings. Our race team 60ft’s in the 1.29 range with this kit!! Fit all shocks except Billstein. Saves 19lbs 800200 $199.99
Saves 20lbs, dramatically increases steering response. Includes urethane bushings for flex free performance and minimum bind. Saves 20lbs, must be used with coil over kit. 800350 $219.99
This is the same kit that the MMR Race Team uses to run 1.29 60ft times!! These kits are great for Street, Strip, or Handling. The kits are made of 6061 Billet aluminum and High silicone BMW spec springs to give accurate rates and prevent sagging over time. The MMR kit offers full height adjustment with the turn of a wrist! Each kit is a direct bolt on and requires NO welding or modification.
800275 $199.99
MMCC9093 $199.95
1990-1993 Mustang Caster Camber Plates, black powdercoat finish
$4700 (ebay reference) motor and trans
1800- 4 cylinder running mustang--- no motor now, figure $1300 for roller...?
800275 $199.99
MMCC9093 $199.95
You miss yours don't you?? . Well, take a look at what I paid for parts, realise im out another 2 grand on top of it for nothing--- so have some sympathy on when you offer me something. Im lookin to lose no more than a few hundred more bucks on this stuff.
