Compatible parts?
Compatible parts?
Just wanted to make sure all these parts I'm about to order are compatible, and if I would do better by adjusting part of it. This will be running on an A4 w/ a Yank 3500 stall w/ stock 273 gears. The gears will be upgraded once the stock 10 bolt breaks to probably 373s.
These were all from texas speed:
PRC LS6 CNC Ported Heads w/ valve job and dual springs
Texas Speed Torquer v.2 Camshaft
Texas Speed & Performance Chromemoly Pushrods (stock length)
GM LS2 Timing Chain
TSP Ported LS6 Oil Pump
Deluxe Heads & Camshaft Bolt & Gasket Kit
Pacesetter Long Tube LS1 Headers
Texas Speed Rumbler X True Duals
Also, the Professional Products Typhoon intake with matching 85mm Throttle Body.
I did a lot of research, but I want to make sure I didn't overlook something. Thanks for any input- it's much appreciated.
GM LS2 Timing Chain
