Valve job?
Old 10-03-2006, 03:52 PM
phoenix1987's Avatar
Default Valve job?
I have a Ls1 with 64k. I will be changing heads in a year or two. The motor is out of the car and the heads are off. My querstion is, should I get new valves, valve guides and valve seats? Or should I do this when I get my new heads?
Old 10-03-2006, 09:39 PM
pwrtrip75's Avatar
unless you sprayed it a ton im sure its fine.
Old 10-03-2006, 09:48 PM
Grimes's Avatar
I really wouldn't bother. Especially if you are getting new ones!
Old 10-04-2006, 05:38 PM
machinistone's Avatar
With that low miles they are fine...check the deck surface for any brinelling or sratches in the fire ring and get them surfaced if necessary. $80
