Whats the Volume on a stock GM fuel pump?
Guys,
How much gasoline/volume does the stock fuel pump in a 2000 GM Silverado K1500 Z71 put out?....
Stroker2112
Stroker2112
Originally Posted by helicoil
I have measured several of these with a CODA volume meter. These systems will put out just under .9gpm at operating pressure KOER. Usually somewhere between .85 - .9 gpm @ 50psi.
Some good data here. It is specific to the GTO. Not sure if your system is the same.
http://www.lingenfelter.com/store/gtofuelpump.html
