best way to clean up power steering fluid from the car?
either the pump or reservoir has been leaking and it's covered the underside of the car in grease (k-member, oil pan, frame, tranny...). whatever was leaking finally broke and there was fluid all over the floor.
can i use engine degreaser under the car and rinse it with the hose?
i'd try that, just do it quick
at the least hit it with some soap and water.
Mine leaked for a little while and sprayed all under the hood and ate the paint off, or turned it pink.
get to work NOW.
get to work NOW.
