cam selection, again
Old 10-07-2006, 02:12 AM
matula11's Avatar
Default cam selection, again
so i am starting another "which cam do you recomend thread" i know there is no one cam that is going to be perfect, but i want your opinions. i have a 2000 ls1 with 243 heads with 918 springs and ti retainers, 7.4 hardened pushrods, katech rod bolts, ls6 manifold, and tb ported to 90mm ish. i still have stock injectors. the car has the standard bolt ons (lond tubes, intake, maf, 3.5 in exhaust) i am currently running a gm asa cam. this setup made 368rwhp. it has a great tourqe curve, but i am a little didappointed with the hp levels. power also drops off at 6400. i want a cam that i spin up higher, shift at 7000 with a limiter of about 7100 or 7200. my car is being set up for road racing and is not a dd, however it does get driven mainly as a street car. what do you recomend for this. and at this point will i be out of injector. please let me know what you think. thanks
Old 10-07-2006, 11:45 AM
matula11's Avatar
right now i am thinking trex. but i don't know. i want a smooth power band form 3000ish up. my goals are 425rwhp, with no more than 450, at that point its just too much power for what i want to do with the car.
