Ticking..Unplug #8 coilpack and ticking stops?
Old 10-08-2006, 02:42 PM
LugNutLS1's Avatar
Default Ticking..Unplug #8 coilpack and ticking stops?
As title says.. I even switched #8 coilpack with #2 to rule out bad coil pack. It ticks then unplugging the coilpack at the wiring harness on #8 stops the tick? Replaced wires and switched around plugs. About 350 miles on this motor with no spray yet.
__________________
Old 10-08-2006, 03:39 PM
1FST99Z's Avatar
what about the fuel injector? did you check that out.
Old 10-08-2006, 04:32 PM
camarochvy21's Avatar
could it be a spring?
Old 10-09-2006, 02:26 AM
CASHss99's Avatar
yea how do you check coils or tell if injector is leaking
Old 10-09-2006, 09:46 AM
Cerebrex's Avatar
to check the injectors just switch out the #8 and see if the noise moves. I doubt that's the problem, though.
