Help car wont start!
Old 10-09-2006, 10:33 AM
81z/28's Avatar
Default Help car wont start!
Got back from a 200 mile triip last night and everything went fine. This morning car wont start. It has electrical power and it shows good voltage but its just not turning over. What should I check first?
Old 10-09-2006, 10:42 AM
Y2K Z28's Avatar
first thing you can do is tell us what kinda car it is and what mods it has.
Old 10-09-2006, 10:48 AM
81z/28's Avatar
its a 00 z28. stock.
Old 10-09-2006, 10:51 AM
craigbb's Avatar
ignition relay would be first thing to check..mine did the same thing and that was the problem
Old 10-09-2006, 10:56 AM
81z/28's Avatar
Im guessing the ignintion relay is up under the dash?
Did you just put a voltage tester light to it?
Old 10-09-2006, 11:42 AM
bjamick's Avatar
check ignition fuse under the hood.. thats really all that it can be if its not the relay.
Old 10-09-2006, 05:55 PM
HeapaShifter's Avatar
It could also be the starter or a security problem. Does the security light or theft light or whatever it is flash when you try and start the car?
Old 10-09-2006, 08:11 PM
81z/28's Avatar
Ok well the security light is flashing when I hold it in the on position. What dose this mean?
Old 10-09-2006, 10:35 PM
BrandonDrecksage's Avatar
vats more than likely...got a spare key? if not..the stealership sells them for 30-40 i think. Its happened to me twice.
Old 10-10-2006, 09:38 PM
81z/28's Avatar
dose the stealership sell new keys for 30-40 or a whole new key/ignition assembly installed for 30-40? lol
Old 10-10-2006, 11:27 PM
new keys. the chip in teh key may have gone bad, so that activates the vats system which kills power to the fuel pump and starter.
