Best engine parts for FI Type Engine
Old 10-13-2006, 12:11 PM
LS2Camaro's Avatar
Default Best engine parts for FI Type Engine
Okay guys So my camaro is getting transformed once again. I am wanting people's opinion on what they think would be the absolute best engine components for a Forged Bottom End stroked Alimunim LS2 Block at 402CI that is about to get a S-85 Turbo front mount and keep Street Driveability. I want to know what compression ratio you would run so I could get the most boost on pump gas and be able to run meth as an option. Money is not an option, just want the best, PERIOD. I want it in this format.
Crank
Rods
Pistons
Cam
Heads
Old 10-13-2006, 12:59 PM
V6 Bird's Avatar
Crank
Rods
Pistons
Cam
Heads
Stock crank
Manley H-beam rods
Mahle or JE boost pistons
get help on cam
and 317 ported heads.
around 8.8-9.0 compression!
Old 10-13-2006, 01:04 PM
LS2Camaro's Avatar
Originally Posted by V6 Bird
Stock crank
Manley H-beam rods
get help on cam
So the stock crank is up to the task, you think for 800rwhp?
Old 10-13-2006, 02:45 PM
V6 Bird's Avatar
definitely. I still havent seen a post on here that someone has actually broke it in half.
Old 10-13-2006, 03:16 PM
Wnts2Go10O's Avatar
harlan took his stocker to 1200? hp. if you want more cubes you can get an eagle forging, they hold up just fine
Old 10-13-2006, 03:25 PM
LS2Camaro's Avatar
I think 1200 is fine, dont want to have to upgrade if I dont need to. Thanks everyone for the suggestions.
