5.3l to 5.7
5.3l to 5.7
Nubie here,I was thinking of doing an ls1 swap in my s10.To keep cost down couldn't I get a 5.3l short block bore it out,put new pistons in it or put some use ls6 pistons in it to make it an iron block 5.7l.On top I would go with a pair of ls6 heads with a 01-02 ls6 intake and a 97-98 fuel rail and built in regulator.Would the 5.3l block idea work.
9 Second Truck Club
11 Second Truck Club
you'll be fine with boreing the 5.3 to a 5.7.
find you a used rotating assembly out of a 5.7 and slap on some new rod and main bearings and new rings for the pistons.
sounds like your on the right track. and the 97/98 rail has the regulator built in it. that's what i'm using to do the ls6 intake swap on my truck.
That's incredible, I would have never imagined you could have bored a Gen III from 3.780" to a 3.898" bore! That's 118 thousandths! Sounds expensive to have a production block bored that much, and that's assuming your first block [4.8L] passes a sonic check to take it out that much.
Ben T.
Ben T.
