Arp Moly Assembly Lube
Old 10-16-2006, 11:24 AM
AppleMac's Avatar
Default Arp Moly Assembly Lube
Is Arp Moly Assembly Lube the same as Permatex Assembly Lube?
I would really like to use a high grade lube rather than some 30wt oil for tqing down my head bolts...
I would go for the Arp Lube if I could find it locally...
I live in Tampa BTW.
Old 10-16-2006, 11:52 AM
Xtnct00WS6's Avatar
Nope...not the same thing. You should just order some from summit/jegs. I didn't feel comfortable using oil either. I read somewhere it helps against corrosion too. My advise is just to bite the bullet and order some.
http://en.wikipedia.org/wiki/Molybdenum_disulfide
Old 10-16-2006, 11:53 AM
Joel_SS's Avatar
You can get the ARP lube from jegs or summit.
Old 10-16-2006, 01:16 PM
AppleMac's Avatar
It is not that I am trying to cut costs... I just want to get it ASAP...
Found a place locally called United Speed World.
No where else carries it. Hmmm Or maybe everyone else was just too lazy too look...
I would have thought car quest would of had it...
Old 10-16-2006, 08:10 PM
NoMoreFWD's Avatar
I have used a few different brands. Initially I thought the price was too high for ARP. After I bought some lube and thread sealer, I won't use anything else.
Quick Reply: Arp Moly Assembly Lube
