Fueling & Injection - How much power are -6 fittings and lines good up to?
Ted J
10-17-2006, 09:59 AM
I'm in the process of planning out a fuel system. I'm wondering how much RWHP -6 line can do?
Thanks!
Nasty N8
10-17-2006, 01:32 PM
-6 has seen 800rwhp all cars and setups are different. we have done the planning for you let me know if I can help put something together for you. http://www.nastyperformance.com/FuelSystems.html
Nate
Old Geezer
10-17-2006, 07:12 PM
Nate
I agree w/ Nate. My turbo BUICK has seen almost 700FWHP, thru a 3/8" [-6] OEM line. The return was only 5/16"... :eek2:
andereck
10-17-2006, 07:32 PM
The only real penalty of a smaller line size is friction. When comparing two line sizes the smaller one will have more velocity as the fluid will more faster in the line. The higher velocity will cause more friction which will in turn cause a pressure loss. The pressure will have to increase (at the pump end) to maintain the flowrate of the larger line to the injectors. Essentially the pump just works harder on its end to maintain the same regulated pressure. I would think a -6 line could support 1000 hp if the pump was up to it, especially teflon line as it has a larger ID when compared to rubber.
Ted J
10-19-2006, 07:05 PM
Sweet, thanks for the info guys! Now on to plan out the fuel system and figure out which fuel cell and fuel pump I wanna go with! :)
jldak318
10-20-2006, 10:37 AM
for my fuel system im going with a -10 from the cell to the pump, a -8 from the pump to the injectors, a -6 from the injectors to the regulator, and a -6 back to the cell.
this way no matter what, i will get enough fuel.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
