Methanol on an N/A and N20 application?
Old 10-17-2006, 04:41 PM
Built LT1's Avatar
Default Methanol on an N/A and N20 application?
How well does Methanol injection work on N/A and N20 applications?
I thought the forced induction people here could share their thoughts, or give a more precise answer than the below information offered from Snow Performance.
13. Can the Boost CoolerŽ be applied to naturally aspirated and nitrous engines?
1.Naturally aspirated/high compression engines:
In this application, water/methanol injection allows the use of pump fuel in all but the most extreme situations which effects tremendous cost savings as well as horsepower increases due to air density increase and realized timing potential. The system is activated by a throttle switch so that injection takes place only during high engine loads when needed.
2. NOS engines: With NOS, water/methanol injection allows the use of full timing even with large (250HP+) quantities. Injection is controlled by the same means that controls NOS injection.
3. Naturally aspirated/stock compression: With naturally aspirated engines with less than 10:1 compression, water/methanol is used typically in warm climates to get the intake temps back to 60°f. Benefits include: 10-15 HP increases from air density increases and full timing, Increased gas mileage, and carbon free combustion chambers. Activation is by a throttle switch adjusted for onset engine load. With this application, the nozzle is sized so that no more than 10% of total fuel consumption at peak flywheel HP is injected.
SOURCE: Snow Performance http://www.snowperformance.net/faq.asp
