WTB 4L60E shifter
WTB 4L60E shifter
Hey, all. I'm putting a '95 Caprice Lt-1 engine and 4L60E tranny in a '48 Chevy Aerosedan, and need a shifter. I'm installing bucket seats and will probably end up fabricating a console but I need all the hard parts between my right hand and the lever on the tranny (hmmm, is the Caprice 4L60E tranny lever different from the F-body's?). Obviously, I'm unfamiliar with the configurations and options so I'll need help understanding what you've got.
Thanks, in advance.
Cheers -- Gary
Thanks, in advance.
Cheers -- Gary
Wow! This things really works! I guess the question now, is, who has the most complete setup? Some of the things I'm concerned about include the shifter plate (P-R-N-D etc), the cable, and whatever bracketry is required at the transmission end of things. I'm guessing there's at least one bracket that holds the cable, and an arm that fastens to the shifter shaft coming out of the transmission with some sort of fixture that accepts the end of the cable. (My transmission now has the fixture that accepts the linkage from the steering column; I'm pretty sure this won't work with a floor shifter.)
Please PM me with how complete your offer is.
Thanks -- Gary
Thanks -- Gary
I have every part that you need. The part that says drive, etc. is part of the console and not the shifter. I can include the shift **** also if you would like. there is one bracket that mounts to the trans. I have everything to mount the assembly in the car also. Its all out of an 02 so its like new. pm me if you want it.
