T76 users inside....
Old 10-20-2006, 11:26 AM
30th t/a's Avatar
Default T76 users inside....
what rpm are you guys seeing full boost at on the street?
most people say to go with the T76 off the start. i dont want anything with alot of lag and I want to produce 600-650rwhp (6 speed) , maybe 700 way down the road on 93 pump gas.
Old 10-20-2006, 11:50 AM
LS1TECH Sponsor
DrTurbo's Avatar
A TC76 will spool very quick and in the range of probably around 3200-3500rpms you'll be at full boost.
Old 10-20-2006, 03:16 PM
MaverickWH's Avatar
Depending on gear, if I step on it at 2500RPM, I'll see full boost (10psi) between 3500 RPM 1st gear and 3000 RPM in 4th gear.
