My engine build so far.. what power should I expect?
Old 10-24-2006, 03:35 PM
Vcious04's Avatar
Default My engine build so far.. what power should I expect?
I am finally getting all the parts for my engine build and just wanted to get some input on what power I am looking at...
02 LS6 Block, Aligned bored, bored .030
Stock LS6 Crank, polished
Scat I-Beam rods, full floating
Mahle Forged pistons -4cc flat-top
MS4 Cam
Dual roller chain
TSP Ported LS6 pump
TSP Hardened pushrods
TSP CNC Stage 1 LS6 heads with titanium retainers and Dual spring kit
Cometic Head Gaskets .040
Compression ratio is targeted for 11.5:1 (TSP is milling heads)
Victor Jr Intake
MSD-6010 Controller Box w/pro data software
Holley Race series carb 750 with billet body
Mac Mid Lengths
3" x-pipe with bullet mufflers dumped
Pro-Built TH350 with shield
Hughes 4k Converter
4.10 gears w/28" drag radial
AJE Racing Tubular K-Member
Granatelli Tubular lower control arms
Granatelli Coil over kit with 200# springs
Lakewood 90/10 front, 50/50 rears
UPR caster camber plates
UPR Tubular upper and lowers rear
Holley Fuel system with cell
I'm sure I am leaving some info out, but thats the majority. Vehicle is going to weight in at about 2600lbs w/out me, and about 2800 w/me.. What power level and times should I expect out of this combo?
I will be spraying a direct port 200 shot after I break her in..
