When launching 4L60E it takes off in 2nd or 3rd, have to manually put in 1st
Ok, this is a 425 rwhp A4 4L60E heads/cam car. It has a built 4L60E that has been in since before the heads/cam swap and the tranny has always worked great.
Yank 3500 converter etc...
After the heads/cam and tuning on the dyno we went out on the street and tried to make a pass from a stop. The car wouldnt go anywhere, fell right on its face till it was like 10-15 mph then downshifts to 1st and takes off. The car wont take off in 1st gear unless you manually pull it into 1st gear and launch it then its you try to get it back in drive real quick and not mess the shift points up or have it bang off the limiter.
What could cause it to launch in 2nd/3rd?
