Drag Racing Tech
I'm having problems....
Old 10-27-2006, 01:29 PM
jshiver's Avatar
Default I'm having problems....
getting excited about running the new brake lines on the rearend. Does anybody have pictures of theirs? I can't seem to figure out how they should run and look neat. How do I attach the lines to the rear? Do I put a "T" in the lines to connect to the line coming from the master cylinder? Do I need a flex hose to connect to the "T" for movement purposes on the rear?
I am installing Strange drag race brakes and the short braided hoses on a new 9" ford housing...just not sure where to go from there or how to attach the hoses....HELP
Old 10-27-2006, 02:12 PM
LS1Tech Sponsor
MADMAN's Avatar
I use #3bulkhead fittings. I put a tee close to where the factory line comes from the frame. I use straights at each end. Then I use a short #3 line to jump from the axle end to the brakes.
__________________
www.madmanandcoracing.com
225-343-9029
