would adding fuel rails be the equvilent of adding a BAP?
pretty simple straight answer,
would having a intank 255L (racetronix) pump with a boost a pump and stock rails and lines
have more or the same amount of fuel delivery as
a intank 255 (racetronix) with stock lines and aftermarket fuel rails.........
I really dont get the in-line pumps. They can only pump as much as the intank pump can. If the intank cant keep up then the bosst a pump aint gonna help anything, IMO those BAP's are straight rip offs and you must be really naive or lazy to buy one.
Oh to anwser you question, I think the 255 with aftermarket rails will flow better.
two different things -
BAP is a voltage regulator for the pump, which ensures the pump gets its capacity of voltage at all times.
In-line pump is an actual second fuel pump added to the fuel line, which assists the in-tank pump.
Both work pretty well.
Aftermarket fuel rails increase the volume of fuel directly behind the injector, making it less likely to starve for fuel.
Rob (Bad30th)
Rob (Bad30th)
I think the point of the 'naive' and 'BAP is a ripoff' comment might be this simple: A relay and a 10 gauge wire run from the alternator can provide plenty of current to the pump. If you need more than 13.5 volts at the pump, you probably need a bigger pump. But the relay and bigger wire to the pump will fill in the space between 'my pump doesn't deliver rated flow by the time the stock wiring has some voltage drop' and 'my pump isn't big enough for my flow needs'.
