LT1 Engine Swap
Old 10-31-2006, 05:41 PM
LT1_King's Avatar
Default LT1 Engine Swap
will a LT1 out of a 96 Z M6 fit a 94 Z A4? the reason i was asking is because i found a motor for a good price and i wanted to swap it out. what would i need to do would i have to just switch my computer out with it or will it not work with the motor? the thing that i'm concerned about is that the new motor had a M6 and mine is an A4. need help ASAP.
Old 10-31-2006, 06:01 PM
UA-Plumber's Avatar
A4 motors are the same as m6 motors for the same years. The computers are programmed different and the wiring harnesses are different. 96 was OBD II and 94 was OBD I The timing covers are differnet as well.
Old 10-31-2006, 06:24 PM
LT1_King's Avatar
it should work good right? a local shop should be able to handle these problems right?
Old 10-31-2006, 07:19 PM
UA-Plumber's Avatar
It should. There are a few minor differences
Old 10-31-2006, 07:24 PM
UA-Plumber's Avatar
The motors are the same. Its the accessories that are different
LT1_King's Avatar
see the motor is $800 dollars with 42,000 miles on it. it was from a 96 Z. and that's the only motor i could find because my car has 200,000 miles.
Quick Reply: LT1 Engine Swap
