Identify these injectors please
Accels...
should have their own pt # on them. Two consecutive #'s are the flow rating. Don't have 1 in ft of me, so I can't tell you first 2, or last 2.
If they are not the "new generation" of Accels, they are likely all over the board on flow, with most of them not coming close to their advertized volume... IE: JUNK.
I can't comment on the new design.. Have not tested them.
Another problem: When doing flow testing, and cleaning, the brown o'rings created so many "leakers", that I had to quit using them. I use only the high quality, black rings... No more leaks.
Use care if they are what is suggested.
