Intake bolt torque specs
Does anyone know the torque specs off the top of there head for the lingenfelter intake bolts? Im not sure if it matters but the stock intake torque numbers might work also. any would be appreciated
thanks guys
Corey
thanks guys
Corey
Oh i see inch lbs is a completely different torque measurement. It says on ls1howto that hand tightening then finally torqueing to 7 ft lbs. should work out with a RUBBER gasket. Do you think that would be fine with a paper one?
